Engine/Transmission (1994 - 1998) Moly lube/ ARP studs
Engine/Transmission (1994 - 1998) Haze
2nd Gen Non-Engine/Transmission Fuel pressure gauge question
Can I use a lube like Federal Mogul Sealed Power assembly lube on my ARP studs just to get it back together this weekend, and then retorque w/ ARP next week? I have to put in new pushrods and the studs run through the rocker towers so some of them have to come out (six of them). I can't get ARP moly lube overnighted b/c it can only ship ground for safety reasons. So my plan is:
-torque w/ SP assembly lube to 122 (currently torqued to 122 w/ ARP moly)
-loosen, remove, clean, and retorque w/ ARP moly to 122 early nxt week.
Again, it's only the center studs that run through the rocker towers.
Nobody local carries any moly lube.
Last time I did a retorque I used some Schaeffer grease that contains Moly or something like that. Real premium tacky stuff.
We started using moly grease when assembling pulling tractor engine at work. I am amazed on how easily bolts torque down. It gives a true reading and doesn't seem like it is torquing down as tight as what torque wrench is set at. I think it is important to get some grease on the threads, but more importantly, between the nut and washer.
