2nd Gen Non-Engine/Transmission Moog or Ac Delco
Engine/Transmission (1998.5 - 2002) Trans Fluid pressure?
Engine/Transmission (1998.5 - 2002) valve spring specs?
I'm doing a complete front steering and ball joint rebuild. Who makes better parts for the truck? Moog or AC. Possible wheel bearing units. Tools needed to do ball joints ??Mini press>
Cheap prices on any parts???? :rolleyes:
My front end parts for my 97 should be here Thursday from Rock Auto.com All the parts are MOOG and was cheaper than my local Napa store even with my business discount. Also with what I bought and our TDR discount I save an extra $31. 00. I think out discount is under turbodiesel.
Rick
Does AC offer lifetime warranty? MOOG (federal mogul) does! I mooged and was very pleased - and that's many miles ago (truck just inspected again today). As far as ball joint pullers - can get loaners (w/ deposit) most auto parts stores. BE SURE to treat the fasteners with nevr seize - for next time!!
Same as Rick here, called Rock Auto. Complete set of tie rods and all the ball joints all from Moog. I believe the discount from Rock is %5, just use the code Turbodiesel. Yours might require the same parts as mine if so I have the numbers still at hand.
