Hello TDR Gang!
About a month ago I posted a topic, "CR Rear Axle Seal Installation" and have now completed this work (once again) on the rear axle last night. Everything came off without a hitch during the assembly, but today I'm already starting to see 'weeping' around the brake drums. I also feel a bit like weeping myself!
This is the second time I've done this job in the past four months.
I'm having trouble understanding how my expensive Amsoil is getting around the seals. The sealing surfaces look perfect, like the day they were machined. The seals pressed in straight & true after modifying the 'slinger' (stamped metal flange) for initial seal clearance. I followed J. Donnelly's (and other's) installation tips to the letter and still oil seeping out of the both hubs.
Some thoughts, maybe the knowledgeable TDR brother's can provide some guidance.
These seals are listed in the D/C parts computer to fit the First Gen. Dana 70's and they are also recommended in Issue 27 (page 14) of the TDR as the hot ticket for the 1994-1998. 5 Rams. When I assembled the brake drum assy's back onto the rear axle spindle there didn't seem to be as much 'seal lip drag/engagement' as w/ the OEM seals. Has the spindle diameter changed between model years (smaller for First Gen. )? I also need do some seal ID homework between old & new.
Also, I installed my new Mag-Hytec diff cover and added Amsoil to the 'modified oil level mark' on the dipstick provided. I managed to get 6 quarts (12 pints) into the rear end to reach this level. I know the OEM spec is 7 pints for the stock cover, I didn't anticpate having to add this much extra oil to compensate for the Mag-Hytec's increased volume. Does this sound like too much oil? It's right at the top mark on the dipstick.
I also need to assure that the vent tubes are not blocked. Maybe now is a great time to extend/relocate them to a more sensible place.
Thanks for any tips or thoughts! It seems that I have to do every modification at least twice to get it right! Is it just me or do others also have this affliction?
Ps: Congratulations! "Old school" on your new position as 'Moderator' in the well-lighted offices of the TRD!
1992 W250 5 spd. 3. 54 gears Banks "Stinger Plus" kit consisiting of 14cm2 wastegated housing, 3 1/2" exhaust/muffler, pyro/boost gage, K&N, 2 1/2" Skyjacker front suspension lift to clear 305/70R/16's Goodyear MT's (wearing alarmingly quick!)
