I've installed several of these kits on both 2nd and 3rd gens, and they seem to work fine as long as you don't try to ask too much of them. A stock truck should see no problems whatsoever, and a few people have Edge EZs on their 3rd gens, and have had no problems. During the shake down run on one I put a guage on, I could pull fuel pressure down to 5psi. I think they'll be fine if you don't try to program them up to 400hp.
On a second note, I've used Holley Black fuel pumps (140gph) on several units, and on a pretty hot ride, I've seen the boost over 40psi, the EGTs up around 1k, and the fuel pressure only drops to around 11psi, using a Carquest fuel filter housing and Fuel/water separator. There are lots of good aftermarket pumps out there. Carter even makes a High Performance replacement for the factory pump on the side of the motor that pump 100gph. But, it's a proven fact a fuel pump makes a better pusher than a puller, so moving the pump to the rear next to or in the fuel tank is always better. Of course, it's always hard to beat a mechanical.....
