Does anyone have some experiences in installing a larger alternator? I'm considering one & like to know if they will work with the truck's exsisting systems without frying wiring. I'd like one big enough to help offset the intake heaters.
If that is the only reason save your money. The stock system has plenty of power for the heaters. On the other hand, if you are adding a large draw component like an inverter then a bigger alternator would make sense.
The alt can be as big as you want, its the load that requires bigger wiring. So if you only have stock equip. the wiring should be OK.
Floyd
The stock system does not have plenty of power. My headlights will dim every time the grid heaters kick on with the stock alternator which is one of the main reasons I upgraded. If it is dimming your headlights it is also dropping the voltage to your accessories which in my case some of them are voltage sensitive.
I had 6 off-road lights, headlights, a CB radio with 350w amp, VHF radio, GPS, radio, cell phone charger, sattelite radio reciever, on-board air compressor and a 25gph fuel pump off of my transfer tank all running at the same time last weekend and had no problems with the factory wiring
Reason for asking is the stock unit is only going to produce less than 40A at an 800 rpm idle, 136A at 2000 rpm. When the grid heaters come on I see the lights dim, I also hear the engine decrease in RPM, which means the alternator is putting out less and relying more on the batteries to make up the difference. In the NW here we get our share of cold snaps, & with the way people drive, + a 80 mile commute if I get stranded I wanted it to be about bulletproof, not juat enough or OK..... Bulletproof.
