96 2500 2wd, 4w ABS.
All I did was put in new front pads and one front hose last night. I had the bleed screws open when I retracted the caliper pistons. Brakes worked fine before this. All brake parts have 50K or less on them - new (not rebuilt) MC, calipers, wheel cylinders, hoses. (reason for new hose yesterday is it had rubbed on something). My ABS pump has the usual problem of dumping all pressure under hard stop, so I run with fuse pulled and have no problem.
I bled the brakes manually but they were very mushy unless pumped up a couple times. Pedal would go to floor under sustained pressure, although I think they probably did that before too. Technically I probably could have driven with them, but I wanted it to be right. Bled with a vacuum bleeder. Gravity bled a little too. MC level never dropped more than ~1/2" before refilling. I put the ABS fuse back in and cycled the ABS a bunch of times, like 20 or so. Pulled the ABS fuse and bled with the vacuum bleeder again. Started truck, pumped several times, had virtually no pedal at all!
Waiting for my bro-in-law to arrive so we can manually bleed again. Any more suggestions? I'm in Katy TX at the moment, but need to get on the road to FL and then to NY ASAP. If I had time and money, I'd buy the rebuilt ABS pump and have it bled at the dealer to rule that out as a problem, though the brakes worked fine with the fuse pulled before.
HELP please!
thanks
kevin
HELP please!
thanks
kevin
