So far, I have been pleased with the results. Since the addition of the sensor, my towing MPG is up at least 1 MPG. My usual numbers towing with this rig were 7. 5 to 8. 5 per gallon, depending on terrain. The truck always pulled strong, especially with the EZ, but the MPG has not been spectacular. I accepted this due to the fact that I have a seriously heavy truck, with LOTS of rolling resistance. The first tank with the new sensor installed, pulling a strech of I-8, E/B towards El Centro has always been a killer. Some 4 to 5 mile long 6% to 7% grades humble many trucks. The Ram used to get in the low 7 MPG range with the 5ver in tow. (Note that I am in the 20K to 21K range with the fiver hooked up. )
The first tow resulted in 8. 5 MPG under the same conditions. About the last 75 miles of this section, I switched the EZ From the lowest setting to the mid level position (tow position). I saw no real detectable power increase, but the EGT's did jump.
On the next leg of the trip I switched the EZ to the lowest setting and set the cruise on 65 MPH, A/C on, and rolled through the Arizona desert at 111 degrees on the overhead. 300 miles later I checked the MPG at the next destination. I was elated to see 9. 5 MPG for the tank!! The terrain was rolling, and finished at 4600 feet in Sierra Vista, Arizona. The truck pulled hard, never missed a beat, and the EGT's were respectable. On some of the longer grades, I would see EGT's between 1300 and 1400 degrees. (This is with the cruise still on)
Always wanting more, I disconnected the EZ for the next leg of the trip. I wanted to see if the MPG would increase if the EZ was not pumping extra fuel into the rail, although I expected a decrease in power. The next leg of the trip was similar to the last. 295 miles, rolling desert, cruise set on 65 MPH, A/C on, and about 100 degrees. I noticed a obivious lack of power on take off with the fiver attached, and on a significant grade I had to downshift to 5th instead of pulling in 6th as I would have prior. The EGT's were noticibly lower though, as much as 200 degrees in most conditions.
The real surprise came when I refueled 301 miles later. The caculator showed that the MPG was exactly the same! 9. 5 MPG at the fill up the next morning. The power lost with the EZ disconnected was obivious. However, the MPG did not increase with the EZ not pumping in the extra fuel. My conclusion is that the ROKK tech sensor installed was definitely worth the investment. The power and fuel mileage promise was delivered. With or without the EZ, the sensor is worth the bucks. With the new sensor, I have realized about a 1 MPG increase in fuel economy. That translates into about 3 gallons of fuel saved per fill up. At the prices of fuel these days, thats about 7 to 8 dollars a fill. The power is nice, and the investment is small. I shoud more than pay for the investment on this trip.
I do have to say that I have no connection to ROKK tech. I just wanted to pass on a good BOMB to the members, that doesn't cost an arm and a leg. Paul at ROKK tech is very helpful, and responds quickly to questions. Take care, Sarge
One thing I forgot to mention. If you do purchase a new sensor, it will not come with an "O" ring on it like the current one. That is because you don't use it on the new install. The instructions were not real clear on that part. Other than that, it's simple.
