After replacing the lift pump and injector pump the truck ran welll. When I started it about 30 minutes later I had to crank on the starter for 3 to 5 seconds which is not normal. The engine usually fires immediately. I drove the truck home parked it shut it off and tried to start it again. It took about 10 to 15 seconds for the engine to fire. When it did there was no fuel pressure. I shut it off and bmped the starter, the lift pump did not engage. The next morning I tried it again and it started immediately with good fuel pressure. It seems as if after the engine runs a problem developes in the electrical system that shut off the lift pump. If allowed to set for a period of time the problem disappears until it is run again then it comes back.
