RobertGray
My charge gauge on the dash is showing low charge but the truck is starting normally. The Wait to Start idiot light does not come on when you first turn the key but comes on when the engine is running and mostly stays on.
Has anybody got any ideas?
I have still not fixed the overdrive which i posted about 1 or 2 years ago. I have been using the bypass toggle switch on the dash. I had to replace the pigtail for the overdrive solenoid to get it working as mine is a 46RH? it has no lockup converter solenoid and is only a 2 wire pigtail, and it took some searching to find the right pigtail if anyone needs it I will find it and post the address.
