Have a 2000 it will sometime start fine sometimes go 5 or more rev before kicking. been through all the posts and tried everything except the clear hose filter-vp. even the return overflow so now now what? here is more info:
LP in factory location and a big line kit with a second pump from diesel dynamics was installed about 1. 5 years ago (that's when i noticed the longer crank) BTW I have not really drove the truck much till a week ago hence the long term prob.
pressure at the vp 26psi not started pumps cycling pumps stop and prussure falls to 0psi in @2-3sec. ??normal?? I assume it is with the small hole in the return overflow or was blowing in the wrong place??
i read too that the vp doesn't like high pressure could it be that?
can i disconnet the return and supply at the tank and vacuum or pressure test the two is that safe on the pumps and the vp.
could the fitting at the tank be leaking after 320K of rough dirt roads? any way to test it?
