More help with codes????????????
New Dealer..... still NORMAL...Rear diff
Does anyone have a better description of these codes?
P0633 Skim key not programmed in PCM
P0606 Internal ECM processor
P0107 Manifold absolute pressure sensor low
P0073 Ambient temperature sensor high
Truck is not running good. Egt's are @ 400 degrees at idle. Lots of grey smoke at idle also. Any ideas?
Digger,
I live over in Memphis and have OBDII scanner software on my laptop if you want to clear the codes and take a look at it.
I will have to take you up on that sometime next week. I am catching a ride to muncie. Thanks for the help.
digger
PM me and I'll give you some contact info. I also added the entire 03 shop manual (thanx to another member!!) to my laptop along with the wiring diagrams so we should have enogh info to get in trouble with!
just a guess here, but make sure that the connector on your air filter is connected. If that is disconnected, it will set P0107 and P0073
