I did some more mods to my truck this weekend. I added a couple of solenoid valves and a single pole double throw (on-off-on) switch in the cab. One solenoid is plumbed into the AFC boost sense line. I have it plumbed so that it is normally closed and will open when energiged. I did it this way so that I will (hopefully) quit breaking parts. With the solenoid valve de-energized, the engine will still develop 20 pounds of boost and get to 950 degree exhaust temperature when you floor it and hold it there. That was about what it did stock. The other solenoid is plumbed in the vacuum line that controls the front axel 4WD engagement. When this solenoid is energized, the front axel does not go into 4WD wehen I switch the transfer case to low range. This will be very handy when I am maneuvering my fifth wheel. Since I have both solenoids wired to the same switch, there is no way that I can accidentally have it in 2WD low range and have the power turned up which may lead to axel breakage. I was showing it off to my wife Sunday and when you flip the switch to "power" it REALLY throws you back in the seat if you already have your foot in it. This is one of the best mods that I have done to this truck so far. oh yeah, I mounted the switch on the backside of the plastic bezel that below the transfer case shifter.
