John do you know if you can use the Special in a twin combo?
Yes, it is what BD uses as their secondary in their R850 kit.
I have not noticed a difference in mpg, no matter what I change. My driving habits are mild 95% of the time, and between the big singles, now the compounds, Smarty, TST, I always stay around 14 in town, and 18+ on the interstate, truck alone. Towing the 5vr, 9-10.
Ahh thanks JJ. Wonder if i would be able to use my stocker as the primary?
If by primary you mean the high pressure turbo, yes. Thats a favorite combo with something like an S400-480 for a set of budget compounds. Its limited to around 550 maybe 600 HP but its good until then.
I'm not really looking for much more power than that. I drive the truck every day and want to keep it reliable. It seems like I can't even do that now. Anyway I have the stock turbo can you direct me to a place where I can purchase the piping needed for this install? I guess I could call BD?
The big Super B Special from BD does spool much slower than the original Super B. For the “towing twins” and the R700 twins, BD uses the Super B as secondary turbo (that is the one mounted on the exhaust manifold that receives boosted air from the larger primary turbo whose exhaust outlet goes to the exhaust pipe). The primary turbo (a large S300 or S400 if from BD) takes in ambient air and compresses it, then sends the boosted air to the small secondary turbo. See my article in Issue 60, p. 94.
thing is that i found d-tech cheap stuff but now after reading it really dont have de quality. but on the other hand someone recomended them in a thread to me so im not sure what to do.
htt have pretty good deals to and i think i will go with a singel that is possible to put in compound when a few bucks turn up. . cause for now i need a turbo and injectors havent driven my ram for a month. miss it alot
I understand that a small turbo will spool quicker but provide less overall boost. So would the cross over in ranges of a stocker and the Special work together.
