Just a little more on brakes. I have a 97 4x4 that I use to tow a fifthwheel that weighs about 14K. I think I am easy on brakes as the front pads have extremely long life. I do use the exhaust brake extensively. My problem is , FRONT ROTOR WARPAGE!. It seems the rear brakes do very little in stopping the truck. I have had the porportion valve on the rear axle removed and according to the reciept, a 1 1/8 rear wheel cylinder installed. The work was done in Sams shop and I sure it was done properly. My knowledge and logic tells me if you install a larger wheel cylinder it requires more fluid from the master cylender to move the piston and apply more pressure on the rear shoes. I have considered installing the EGR assembly on the front ene but my last cinservation with Sam was that the cost benifit was still in doubt.
Any thoughts on my problem or the benifits of larger wheel cylinders?
