More TPS Questions
Nice First Gen on Ebay
I checked my TPS this weekend when I was at the shop changing the fuel filter. It read 0 volts at idle and 0 volts at wide open throttle. It jumped all over the scale during "acceleration". I am assuming it is junk. Anyway, does the TPS have anything to do with the cruise control? The cruise control died about the same time the truck started shifting in and out of overdrive. And by the way, I found out how much fun it is to get a Dodge truck with a 16' stock trailer stuck in a 3 foot deep snow drift in a horse pasture. Only took an hour to shovel it out(Whoops!!! needed more speed or something and should not have tried turning).
Jeremy Sweeten
1992 Dodge W-250 4x4
Cummins Diesel, Intercooled,
LE Package, 165K, AT, Warner Hubs, 3. 54 limited slip differentials, 3" straight pipe, K&N air filter
http://home.earthlink.net/~sweeten1/index.htm
Unless I'm missing something I would say that it is toasted. It should not read 0 and it should also not jump around as you slowly and smoothly open the throttle up to wide open.
The service maual says that this indicates a failed or faulty TPS and time to replace it.
Sorry for the bad news 'Case'.
If someone else has any ideas please jump in here. I do not have overdrive so I can't say if that would also affect you, but logic suggests that if it can't make up its mind what gear to be in then OD will not work either.
I think you may try to find one off a wreck and see if it behaves. That will save you some money atleast. If not, well... ..... ugh!
Bush
93. 5 D250 4X4,HD Spring Pkg, Rancho 7000's, Rear Swaybar,Dual Shock Front Stabilizer,BD Injectors,31/2" Mandrel bent exhaust,16cm 'Hot End',Modest Pump Tweaks/Timed,K&N Air,Isspro Pyro,Tach,transmission Temp,Auto Meter Oil Filled Boost Ga. , 3:54's, 4 Speed Auto, Clubcab, Aftermarket Reclining Buckets w/ctr Drop Down seat/console, Black over Silver, 21psi,285-65R-16's,American Racing Clear Coat Mags, Amsoil 15W-40HD Marine,12,000 lb. Warn Winch,KC Spots. 97,000 Kms.
