Engine/Transmission (1998.5 - 2002) More transmission questions
2nd Gen Non-Engine/Transmission Is It Broken In Yet??
Engine/Transmission (1994 - 1998) Rear disc's???
I have a ATS stage IV 47RE. What pressures should I see? It shifts pretty hard, would lowering pressure smooth it out? If so, how do I do it?
pressure is to hold the converter from slipping it is set high for that reason
your ATS is a performance trans built to hold a lot of HP and TQ
i think the line pressure is around 160psi, stock is around 80psi
when you are making tons of TQ you need lots of line pressure to keep it from slipping
hope this helps a little
Scott
