More turbos
How Many Trackbars
9 cm2 Turbine and LARGE Truck Transmission
Has anyone given any thought to splitting the exhaust in half and installing a 9cm/2-hx35 for each half? Iam not an engineer or mechanic, but I would think this would be similar to an Hx70-18cm2. Imay have found a use for the Banks twin ram manifold, cut the rams in half and feed each one with a turbo. Any thoughts on this would be appreciated, as I am giving this some serious study. I just don't know enough about the dynamics of turbocharging to decide if I should proceed.
96 2500 4x4 5spd 3. 54 grs,#10 TST plate,AFC spring kit,16 cm turbo,CUSTOM 4" exhaust, (turbo to tail),K&N RE-0880 filter,TST guages,370HP injectors,3800 rpm governor spring kit, Mcleod dual disc clutch(street),305/70r16 Goodyear Wrangler MT tires
If the boost air is all going thru the same inner cooler wouldn't a bigger tubro be just as good as two small ones?Just a thought.
95' 25004X4,AT,Driftwood,Banks,Warn fender flairs and running boards(Play truck)95 3500,5 speed,driftwood,Banks&phscotty,30,000 GVW apple and tractor hauler(work truck)
I am actually considering two intercoolers, with a stagger mount to allow hose connection. Then going to dual 3" exhaust, which I believe should breathe adequately enough to keep EGT's in check. I guess I'm asking if there would be enough of an airflow gain to warrant such an approach?
I have always read that the more cylinders feeding a turbo, the quicker it can spool up.
A six can spool a turbo quicker than a triple. That said, SEQUENTIAL turbos, with a little one spooling up quick, then a gate opening up to allow a larger one to come online would probably be the best system from a throttle response/hp output standpoint, barring cost, complexity, space etc.
ld
