Hello,
My truck has had a quirk since I have owned it. The truck will start up fine, and run for a about 30 seconds, and then begin to sputter and stall sometimes in the morning. This problem is always in the morning, and not weather dependant. If the truck completely dies I have to pump the manual primer about a gillion times, and then it will restart. This has not been a huge problem, because in the past it would do it about every two months or so. I found that at the first sign of a morning sputter I could change the fuel filter and the problem would go away for about two months. For the last 180K miles it was just a reminder to service the fuel filter.
The truck only did this first thing in the morning after it sat all night. The symptoms seem to be aggravated on my drive where the truck has a few degrees of up slope. This has never happened leaving work, even after being shut off for 24 hours or more. Two weeks ago it began to sputter at the end of the drive when I lifted off the gas pedal. I did the expected maintenance, and the problem did not go away.
So this week the truck is sputtering when I lift of the gas pedal at the end of the drive. So far, I Have found I can keep it running by playing with the accelerator pedal. The sputter lasts about 10 to 15 seconds, after that the truck will drive fine for the rest of the day. Any advice, on what to check or replace would be appreciated.
