most powerful mixture?
Wix or Fleetguard Filters?
5.9 vs 6.7
I have a snow stage 2 water meth kit and I am wondering what is the most meth i can run without causing damage to the engine. I am trying to get up to 550 at the wheels. Right now with the Smarty REVO helix 2 cam flux 1s and stage 3 garret i am at 460-470ish. Is there any way possible to get to that 550 without a fuel system or is that what i need to get to my mark? thanks guys
I made 558 hp / 998 torque with stock cp3, stock injectors, stock cam, etc.
This was with Smarty 4. 11 #9, TST 4/1, and MP-8... running a SPS 66 turbo and a walbro lift pump.
--Eric
You might be dropping rail pressure. You might make more power on lower settings. Get the FASS or equal, it's a basic building block to HP. If you want power you need fuel and air.
I didn't see any fuel pump upgrades, that can deffinatly hold you back.
Do you have head studs yet? I don't know about straight water, but I'm thinking that you'll be replacing a blown head gasket if you don't have studs and you run water/meth.
Along with others you need lift pump upgrade. With out the banks and your other mods you should be over 500 easy with the correct tuning. That is without any meth.
I need to upgrade my sig... i just got my truck back and it runs fantastic. Banks is off... here are my mods
-Smarty Revo
-Flux 1's
-Helix 2 camshaft
-Sportsman springs
-Garrett Stage 3 Turbo
-Studs
-EGT, boost, trans, fp, rp gauges
-HTS transmission
-stage 2 water meth
I am planning on upgrading my fuel pump in the next month or 2. I would imagine this would be pretty beneficial to my numbers?
