Details here: TDR Privileges
Have any of you put this on your trucks? If so, where did you mount the hydrualic reservoir? I just got mine in from Genos and the reservoir has an slight angle to it, but not enough to match the only resonable locations on my firewall.
Seems most people are zip tying them to the wiring harness right above the master . Just be careful that no water can get into it from above or when you clean up under there .
From what I've been told, SB recommends it that way, I some what modified a tab in that area and hard mounted it at a slight angle, try to get pics later !
