Get a "boost bolt" from Geno's. You remove one of the intake bolts on the flat surface near the valve cover, replace it with this bolt, add the barb fitting and hook up the hose. The hollow bolt feeds boost through to the hose. It will likely come with good instructions, most Geno's stuff does. Super easy install.
