MPG Cap
Pacbrake W/Autoloc Question?????
US Gear Exhaust Brake: Clunking
Check out the Cap that reduces drag by 30% and increases mileage by 3 MPG. The link is on the second page of Certified Mileage post. It will be here soon I hope.
I could make this out of ply board but I dont think I could get real good rounded corners. Does anyone have any other ideas on materials to make this. Are there place who make custom fiberglass thing like this and what about plastic. The only other thing I can think of might be Aluminum.
2001 ETH/DEE ST 4X4 SPACE SHUTTLE
JPonder - I hope that if you're planning on putting that monstrosity (hehehe #ad
) on your truck, that you'd only do so for the fuel mileage investigation. Any top of that sort looks very user unfriendly, not to mention bu-t ugly.
Y2K 2500 Cummins ETC/DEE, SLT+, 4X4, Quad, LB, Intense Blue Sport, 3. 54 LSD, rear aux. springs (camper special), sliding rear window, all options except cab clearance lights including agate leather, totally stock engine, silencer ring removed, "stealth," mod to run fogs with high beam. Since everybody else listed their toys, I will too.
1995 Kawasaki ZX6-R (For Sale)
1990 Toyota Celica
1983 Mazda RX-7 GSL (For sale)
Maybe it'll Grow on ya!!!! Its just a toneau with a slant!!!!!! It looks like they connected it right to the back of the cab after all the truck didnt have to move right. I geuss you could connect it with one of those rubber gaskets. Wonder how much of that 30% drag reduction you would lose if it was not connected?
Dont be shy Come on with it!!!!
Jponder, sorry about the slow post. Something to do about kids, vacation, a birthday party etc. Here's the url for the cap the two students worked on and pictures to boot. Enjoy. Http://mars. acnet. wnec. edu/~ehaffner/did.htm
Ps, as for construction of the cap, you might try it the way the kitplane builders do, with foam core board and fiberglass. You can basically shape the cap with foamcore board and then put a couple of layers of glass over it. Gives you great strength to weight. Probably build a mold of plywood, and lay it up from there. Also, As I recall, one of the campershell companies made a cap called a "fastback" that had a similar taper to what the kids did. Might want to look in to it. Possibly leer, but my memory might be wrong
01. 5 ETH/DEE QC, 2500 4X4, 3. 54 Everything but leather
[This message has been edited by Ranger Dick (edited 03-05-2001). ]
Originally posted by Scooby:
That fast back looking shell I beleive is called the Top Gun by SnugTop.
It would be interesting to see to see them use a REAL truck instead of a model!
Cool I went to http://www.snugtop.com and i saw it. I could live with it if it did indeed make my trug more drag efficient but this is pretty different than the one in the test. My Uncle built an Aluminum camper back in the 40s and I think Aluminum would be the way to go.
Scooby - If you're talking about the model in the fluid (water?) tank, I had the same thought. I wonder how it would come out with a real truck (QC or EC) in a wind tunnel. Hmmmm.
- JyRO
