Mud flap anti-flappers
Loading small tractors/ 4x4's, etc Ideas /examples??
Dimmer for Gauge lights
I just put a set of cheapo NAPA rubber mudflaps on the back of my dually flatbed. The one on the exhaust side gets blown up and over the exhaust pipe, and ends up sitting on there. It's not melting, but I just put on a Jardine exhaust and once I get the stainless tip, that flap will mess it up good. . Any suggestions? Bolting some strap steel to the frontside vertically to make the flap more rigid? Some bar attached to the flatbed sticking down to keep them from blowing backwards? Or do those weights work? Any suggestions would be appreciated.
'97 Jeep TJ - Tons of stuff.
2001. 5 3500 Chassis Cab 4x4 163"wb - HO/6 speed/4:10's, SLT, other stuff being added all the time. .
What a friend of mine did was go to Home Depot and Purchase a chrome bottom door kick, it measures about 10" wide and 36in long, you could cut and mount it on the back side of the flaps, giving you a nice chrome look from the back of the truck with the flap extending down past the chrome by say 2 or 3 inches... it looks great and relatively cheap, not to mention that it ads alot of rigidity to the flap on the exhaust side. I thought it was pretty smart of him... just an idea...
1998. 5 QC long bed 4x4 24v Auto 4. 10s spinnin' 33x12. 5x16. 5 mud BFG's on weld roadhawks factory center caps retained K&N Bushwacker fender flairs Dodge/Cummins 1ton mud flaps
I ordered a 10" extension from Jardine. Insert it before the last section It is flared on one end ,you can cut the pipe to suit your needs. I installed mine with 20" flaps from NW custom.
Got anti-sail brackets and lower weights from a truck supply co. These babies don't move and look pretty good if I do say so myself!
98. 5 3500 SLT Quad 6X6 * 3:54 Auto * Waterfall black/red * Custom dually flaps * Rhino lining * All acc's w/leather * Muth signal mirrors * K&N * Catz MSC's * 55watt back up lights * Optima Red Tops * 80/100 Head Lights * Silencer ring "AWOL * BD exhaust brake * Banks EGT/Boost/Temp gauges * Mag-Hytec DC&TP * SS bug screen and fender trim * SS Stull diamond line running boards * SS 4" turn down * grill inserts
My Dually
[This message has been edited by Justbeamn (edited 05-22-2001). ]
Dave,
Did your new diff. have all of the parts? I thought they were priced about 250+-?
Frank
01 White, Quad Cab,Short Box ,Sport SLT+,5 speed 3. 54 Ltd-slip,4X4,line-x ,Nerf bars,fiberglass tonneau cover
