Muffler flow direction
smarty vs PPE
2006 engine noise
Just got a new muffler w/ cat test pipe from AFE, and was wondering which way the flow goes through this thing. I know I can call the dealer, but wanted to know if anyone has tried both ways and noticed any difference in sound. Should it flow into the holes or over them?
but, into the holes also catches and muffles the sound... hints muffler. what good does it do over the holes... . ?
Less restriction over the holes and a little quiter into the holes your choice. Guys have mounted them both ways.
What JFalkners said. Had the MBRP kit 169. 00 at dppi. installed it my self using the into the hole logic. nothing wanted to line up right so went to the local muffler shop for some custom bending. The muffler guy in broken english as far as i could understand let me know i was an idiot and had it installed backwards, he pulled the muffler flipped around(over the holes) and every thing lined up perfect. So have ran the MBRP in both directions absolutely no difference in noise levels
Mark, thanks for the reply on this thread and my other exhaust thread. Should have just called you from the beginning. Im trying to install the system today, don't know if I'll have enough time.
