muffler or not????????
Theft proof your Ram (kinda)
1/2 the valves engine question.
Do it only if u want more power, qicker turbo spool up, higher mpg's & lower EGT's #ad
94 2500HD 5sp 4. 10LSD w/GearVendor OD,Killed Kitty w/ 9 lives & muffler fell off. Geno's drainplug, 120,000 miles. NRA Member. V1 in the window.
Get rid of the muffler and kitty!
1996 Dodge 2500 4X4 SC, SLT, Cummins 12V, 5-spd. , JRE 4" exhaust (my kitty ran away into the woods and the muffler fell off!), TST 280 HP/685 Ft-Lb Uprate Kit, AFC Spring Kit, Horton Fan Clutch, Jacobs/Ram Exhaust Brake, MagHytec Differential Cover, Prime-Loc, Rancho RS9000 Shocks, Combo Gauge, K&N Air Filter, Brite-Box, Geno's finger-touch oil pan drain plug, no turbo silencer ring, full-time fog lights.
Just a quick question in regards on getting the cat out. When removing do you have to take the tail pipe and muffler off and then the cat or is there enough room to remove the cat without pulling the tail pipe and muffler out (removing it).
Paul
Flatlander,
It CAN be done! DC provides a cool little "handle" on top of the muffler. First, remove the bolt from the tailpipe hanger. Then hook one end of a come-a-long to the "handle", and the other to your receiver hitch, (or bumper). Remove the hanger at the tailpipe/cat junction, and crank the come-a-long. The muffler will move back far enough to remove the cat. When you put it back on, release the come-a-long and line it up! It should slide right back in.
'96 Regular Cab, 113. 5K, SLT 2WD auto 3. 54, Vista topper, Pillar-mounted Autometer Boost/Pyro, transmission temp and oil pressure guages under dash, starwheel spun
fire803: I tried it. Pros: Nice sound. Cons: a bit on the loud side. I put it back together. Don't like to attract attention!
1995 2500 SLT Club 4x4, auto, 3. 54, 3300 pound Elkhorn slide in camper, AirLift air springs, Ricka dual wheel adapters (used only with the camper on), K&N, DC tow hooks, Rancho RS9000, Hellwig rear sway bar.
108,000 miles and counting.
I did mine last week, and yes it does take a little bit to get use to. But the more I hear the way that it sounds and the response I get, its worth it. When I am around in town I just watch how hard I press it. I can already tell that there is more power, as far as mpg not sure yet. And the EGT's while towing has not been checked yet, next 5th wheel tow is after Thanksgiving. .
Rick
RICK
97 2500,CC,5 SPEED, 3. 54 Limited Slip,Psychotty System,K&N, ISSPRO 3" Pyrometer,Silencer Ring Removed
12,000 RBW 5th Wheel Hitch,25' Excel 5th Wheel,Rancho RSX17000 Shocks,Amsoil Dealer,Straight Piped
Firefighter, you know once you take them off you can always go back but you won't. Be sure and salvage the cat its worth somewhere arond $800. Muffler shops can cut em out if your talking resonator and muffler removal.
Stephen's 1995 Dodge Cumming Automatic 3500 in Sanger CA. Pulling 35 Foot 9600 lbs 5th wheel. BD fuel plate 230HP,Air Filter Boot Removed, Gutted Cat, Vibrating Mirrors, Sreaming Tubro
