Muffler
Rust around tail lights
Bad DEE trannies from vendor
I am running an empty cat with no muffler, just straight pipe right off the cat. Is their any muffler i can run that will quiet it down without much or any restiction or power loss?? #ad
My wife is afraid of it cause its so loud!! #ad
1995 Dodge 2500 SLT Reg. cab 4x4 Auto,Long Bed 12 valve, 3. 5 rears, K&N Air filter 112,000 miles Anti lock brk sys, 305/70-16/Mickey Thompson Alum. wheels,Leer cap, Nerf Bars, Black/Black C/D Player Overload springs, Reese Hitch, T. C. Lockup switch, Cats dead, straight pipe.
My wife had the same complaint about my straight pipe. I completely removed the cat however. To keep things happy on the home front, I installed a Dynomax Ultra Flo muffler that was 3" in/3" out design. This is a straight through design, and changes the exhaust tone quite nicely. The part number is 17223. Buy it from Summit Racing, they had the cheapest price I could find.
Good Luck!
Walker 21471. 4 inch straight thru. You can use reducers to use it on a 3 inch system. Then if you decide to go 4 inch, you already have a muffler.
1996 3500 Clubcab SLT, auto, 4. 10 limited-slip, TST #5, 370s, AFC spring kit, Psychotty, Dunrite converter, Trans-Go, DiPricol EGT, boost & trans temp. gauges, 9 ft. aluminum flatbed and tool boxes with Venco dump. Custom front bumper, Hadley air horn, PowerVision mirrors & 4" Stack Exhaust.
I am in the same position. My wife wants me to quiet the truck down, so I am looking for something to take the edge off. I got my truck inspected yesterday, so I put the cat and muff back on. I drove it a few miles, and I couldnt stand it. The straight pipe went back on that afternoon. I love the sound of the exhaust, but I need to keep the peace. This does give me the excuse to go with a 4" exhaust, so this compromise might not be that bad. Still undecided on what I am going to do, so I will be watching this thread closely.
98 QC 2500 2WD 12 Valve Automatic, 3. 54 Mag-Hytec transmission pan. DTT Valve Body. Wrap around black Grill Guard (BIG solid steel one. #ad
AFC controller adjusted, Mopar mud flaps, Camper package, 2001 Tow mirrors, Cat ran away, No Muff
My Mustang
My Ram
The Wrecking Crew web site for Junkyard Wars
Go Aggies!!!
[This message has been edited by Conleyjo (edited 03-06-2001). ]
I too tried the straight pipe approach and
didn't like the "cornbinder" sound. (the rest of you BOMBers, don't get mad at me, just personal preference. . ) Anyway, I installed a Dyna Flow, 4", straight through
racing muffler. What a difference!! The truck is still louder than stock but a VERY low, loud sound. Going through town on residential streets, I can set off the cheap car alarms just by the low resonance/vibration of the exhaust. He, He...
A very distinqued(sp) sound.
97 2500, extcab, 4x4. BFG 285/85/16 AT, "warmed over" pump, JRE Stage III plate, AFC spring kit, BD gov. spring seats only, 370 injectors, K&N, 4" Edwards Exhaust with Dynomax straight through racing muffler & 5"tip, (Cat got "lost"), EGT, boost, oil & transmission temp. gages, Low Stall torque conv. & BD valve body, silencer ring "exiled", Grover Emergency air horn and a multitude of strobe lights and switches (Vol. firefighter)
Correction of previous post.
It's a Dynomax muffler, not a Dyno Flow. .
Sorry, still haven't had my morning coffee... .
Another approach, sorta like having the truck quite and great sounding at the same time, add insulation. By insulating the back of the cab below the rear glass (it's currently bare metal) you can make a huge improvement. To really help, remove the complete interior and do it right. A search will yeild ideas on materials and technique.
Try a Walker 21468, 3" straight through, nice sound, 0 back pressure, I use these on my 3" turbo Diesel systems.
Ted Jannetty, Owner President, Jannetty Racing Enterprises, Inc.
97 3500 4x4 club cab 5spd. RED, JRE custom power kit, JRE 4" exhaust
JRE 1/2 inch fuel system, Bosch 300 hp injectors, Prime loc,
Cummins chrome kit, US Gear 20% over drive, 3. 54 posi, Autometer
Ultralite 50lb. boost, and Pyrometer, BD exhaust brake.
Horton fan clutch
99 Ski-Doo 800 Formula III Pipes, reeds, studs and clutching 172 hp
99 Honda Forman 450 ES jet kit, pipe, lift kit, 27" Mud Runners
2001 Ski-Doo MXZ 800 X stock for now 140 hp
2000 TransAm Ram Air WS6 Flowmaster, K&N, Granatelli Mass air meter, LS1 Lid 370 hp
1973 Camaro Rally Sport Street Strip 850+ HP
Here's another option to think about. Because of clearance problems past rear cross member/NP205 I'mpretty much stuck with 3" to a point past X-member. '98s use an odd little resonator 3" in 4" out ahead of the muffler. Picked one up at the wrecking yard and a Walker 54 150 (4" mandrel bent tailpipe) and I gotta say its not too loud, kinda deep and throaty, breathes good and still lets you know when you get on it.
2 cents.
Jones
Jones
'84 Ramcharger w/CTD, non-gated 12, torqflite, NP205, Dana 60 and 70 w/ 3. 07s. Straight piped 3" to x-member 4" the rest of the way.
