I want to replace the WHOLE switch assembly not just the STALK. Will the procedure still work without pulling the wheel off ?
Tried pulling backward hard on the up/down lever and it's not coming off.
You do not pull it back, pull the stalk straight toward the driver door. The entire switch will pull out. Just make sure you pulled the two phillips screws that I point out in the link Bill provided.
I should have highlighted the screw holes in the photo before I posted it. Look at the top photo and you will notice 4 holes in the switch and bracket near the base of the stalk. Two of the holes are in the black bracket at 2 and 4 O'clock. There are also two holes in the light blue part of the switch, just to the right of the holes in the bracket. The switch is pulled apart in the photo about 1/2 inch. So when the switch is in the truck, the two screws go through the black and thread into the blue. They will be tight up against the steering wheel when in the truck, so turn the wheel right or left to get better access.
When you put the new switch in, you can just leave the screws out. The switch snaps into the bracket pretty tight.
IF I understand you correctly, the tilt steer lever is preventing you from removing the plastic cover? If so, it should either pull backwards toward the seat, or have one screw that has to be removed, and then come out.
The control stalk and circuitry is all one unit.
View attachment 84415Sorry, misunderstood what was stopping you. From the FSM.
TILT LEVER KNOB RELEASE
REMOVAL
1. Remove the screw (1) securing the tilt lever knob
(2).
2. Remove the steering column opening cover (Refer to 23 - BODY/INSTRUMENT PANEL/STEERING COLUMN
OPENING COVER - REMOVAL).
3. Remove the lower shroud.
NOTE: Use special care not to pry on the clockspring electrical connector when removing or installing the
mounting screw located next to the clockspring.
