OK, I have not proved it out, but this is off the neighbors truck that was doing the right turn when he selected left and vice versa. I picked up the recall switch for him that fits the 3500 for $25 and changed it. I had the old one sitting around and finally got around to pulling it apart to see what might have gone wrong. It appears to me the lube they use for the contacts finally picked up enough metal from the circuit board that it became conductive. If you look at the grease you can see how it "hangs over" from one contact strip to another. I wiped it clean and I'm assuming the problem is probably fixed. One of these days I'll reinstall it and see if it works. If your having trouble with your multifunction switch I certainly would give it a try first before buying a new one. Especially since you don't have to remove the steering wheel to change it. The first two photos show how to pull the two screws out and slide the switch from the bracket. Just give it a sharp pull after removing the screws and wiring and it pulls straight out the drivers side.
The top photo shows the parts slightly pulled apart and the screw holes are on the right side of the photo. And remember we are looking at the switch flipped right to left.
