multiple wheels/tires tpms sensor question
Thoughts on purchasing a new Ram 2500 CTD
Rear tires wearing more than front?
Is there a limit to how many different sets of tpms sensors (tpis in the case of my 2016 3500) that will sync to the truck without any programming? I currently have two sets of wheels/tires that I switch back and forth between and the sensors self sync each time. Can I add a third set?
As many as you want, MOPAR has no programming at all.
Means they are not programmed in any direction, if you fit the wheels then the TIPM accept it within 10 Miles or so and forget about the older ones.
Thanks for the info. That is what I have been hoping. I plan to use Mopar 68249197AA sensors, same as I bought two years ago for the second set of wheels/tires
