I have been trying to figure out why the pedal on my '95 seems soft and why it doesn't stop like I think it should. I went from a 3rd gen to 2nd gen so I knew the brakes would be a little different, but these have actually scared me a couple of times. I tried backing up and applying brakes to see if maybe the drums were out of adjustment, but that didn't help at all. I checked the master cylinder and it was full to spec. Then I followed the vacuum line from the booster to the pump and discovered that right where it exits the pump, the hose had completely collapsed and sucked together in the middle
. I pulled the vacuum line off of the cruise and felt some suction so it is still getting past, but I am guessing it is greatly reduced. I need to pick up a vacuum gauge and see what it is pulling.
Question is, can this large diameter vacuum line be found at the local parts house or is it a dealer or Cummins only item? Thanks guys!
