bighammer
Super Moderator
Driven about a week ago and parked next to garage. We got a bunch of snow last night and I wanted to plow the road this morning. Temp is about 20° and it cranked normally but wouldn't start. I cycled the key to re-heat grid heaters, but the light went out right away. (never remember it doing that) I did notice hearing the lift pump cycle. (replaced a couple years ago)
Code check gave me:
p0633 SKIM Key Not Programmed in PCM
p0646 A/C Clutch Relay Circuit Low
p0514 Battery Temperature Sensor Performance/Rationality
Seems like I remember seeing them before, but maybe I'm wrong. A/C was removed when I fixed heater doors, but not sure why the SKIM and battery codes.
I'm considering using my tractor to push it into the garage to be able to work on it more easily, but with all the snow and the plow on it, not an easy task.
Code check gave me:
