Installing relays is the answer to all the problems mentioned here. In our Dodges, the switch seems to be the point of greatest resistance. Current passing through a resistance will create heat, a warm component will increase its resistance, which makes it warmer, see where we're going with this? There are two power feeds into the switch, one is for the headlights, hi and low circuits are in series until the dimmer switch. The other feed is for the parking/marker lights and the instrument panel lights. Either can be a problem.
It takes voltage to push current through a resistance, this resistance could be the actual light bulb(the load) or a undesirable source like a light switch or poor connection. Voltage used crossing a load is called voltage drop. Say you have 13. 5 volts available from a source(batt/alt), that 13. 5 is used up (or dropped) before returning to the power source. Now say the headlight switch is a undesirable resistance and it takes 1. 5 volts to cross it, that leaves 12V to operate our load (the bulb). The result is a reduction of light output and heat being generated in the switch. After putting overwattage bulbs in my ole Lebaron work beater the switch would overheat and pop the circuit breaker in the switch, causing the headlights go on/off once the switch got too hot. I checked voltage drop on the HL feed. One lead of the voltmeter on B+ and the other on the B+ pin of the bulb, 2. 75 volts drop! My truck only has . 3V drop to the HL, so no problem or benifit there. With trailer tow, the trailer is already relay controlled.
The fix: (using HeadLight as an example)
Take a cheapo relay and bypass the high load current from the switch. Same basic deal to bypass for trailer lights.
Parts needed:
1. A relay and wiring. I'll give ISO numbers but my favorite is a GM high blower relay and harness from the junkyard. A bag of a dozen make the guy at the yard look at you funny.
2. A fuse holder. For your new power feed.
3. Wiring info. Wiring diagrams prefered. Sometimes the HL wiring splits way before reaching the HL bulbs.
4. Soldering iron & shrink tubing. Scotch Locs suck, so don't use them. Your trying to repair a problem, not make a new one.
Procedure:
1. Find the wire that is feeding the HL and cut, wire the end from the HL switch to pin #86.
2. Wire pin #85 to ground.
3. Take your fuse holder and wire it to pin #30, use a good power source very near the battery.
4. Wire pin #87 to the HL wire that you cut.
Done. Now you have eliminated the voltage drop from the feed and have about 500 milliamps of current passing through the HL and dimmer switches. Now you can add driving lights, wire your trailer with all kinds of lights, or what ever. Relay's rule man.
I'll help in anyway I can, if you are interested. Early Rams really need this, gassers too.
Sorry to be so long winded,
HTH
Wayne
