I am the original owner of a 95 Ram 2500 equipped with a Cummins with about 8500 miles on it. Yesterday while warming it up it died and will not start. The fuel shows no sighn of contamination and is clean and green. I checked the banjo fitting on the pump side of the filter while cranking and fuel flowed. I also cracked a few injector lines while cranking and again fuel flowed. I am a long way from any service center and have no way to check for pressure or volume. Any advice would be appreciated.
The fuel solenoid appears to go up and down with the ignition switch but maybe it's not going up completely?
