I have experienced on-going problems with the A/C in my '01. Replaced a leaking hose about 18 months ago..... a Dodge dealer only item. Soon after, my a/c was dead again; this time the evaporator was leaking and had to be replaced. The new evaporator lasted almost 6 months and it started leaking, so out came the dash again! The second replacement evaporator was of a slightly different design than the first replacement, so I thought maybe Dodge had found out they had a problem with the first design and changed or improved it. Maybe not.
Long story short, my a/c is dead again. It has been almost 6 months since the second evaporator replacement. All the lines and fittings are dry and no dye or anything shows up with the black light. So, today, we added more juice to the system and will check again on Monday or Tuesday to see if anything shows up.
Any ideas from any of you folks? Is anyone else experiencing on-going a/c problems?
