well after reading about bypass filters i figured i would get one for my 06 ctd. lots of soot in the oil that i just dont like! so i tried to find a good set up and i decided to go on the amsoil BMK-11. very nice set up. but i did not like the hose that came with the kit or the brass fittings. reminded me of my old Dart to much. so i just orderd the bracket/mount for the filter and a big bypass fitler. all the AN fittings and SS hose i got from Jegs. i just love the black and red fittings, match my INFERNO red truck!
First i had to find a location fro the filter. but being that i wanted to run the largers one they have, i only had one option. if you look on Amsoils website they show what a few people have done for there mounting. and i decided to flow that. so i fabed up a bracket to go next to the intake. angled it at 65 degrees, and called it good!
as for the oil return, i just dont like the way it looks going in to the oil cap. and i also have a thing about pounding holes in a good oil pan. but after reading Mundgyver's thread on the Spinner 2 bypass, i loved the idea of removing a return plug on the side of the block to get a clean oil return. so i ordered a piece from Cummins northwest and an oring, cut the tube, and welded in a SS AN fitting. the hard part was getting the old plug out. i used a vac to try and keep the metal shavings out of the oil (chaning it any way) when i drilled a small hole to get the plug out... ... ... ... ... ... ... . that just did not work to well. so i had to make a few more... ... ... ... and broke a punch, IN THE OIL PAN... ... . but i did get the little SOB out. and by the grace of god, i used a mag pickup tool and got the some of the punch out, still a little pice in there someware. but its way to big to go anyware. i hope the mag drain plug will get it.
that was the fun part. the hard part was the SS hose and getting it in to the fittings. but i got them, and here is what it all looks like!
And yes i will take the return line off to get to the filter!
