well guys bd tore my transmission apart to see what damage i had done to it.
i have had it for around 6000miles, i've done 250+ 4wd 25psi launches. i've been in 1 sled pull so far, i have locked the transmission up in 1st gear and left it that way all the way through the quarter. the weekend i got the transmission in i drove home at 22kgcvw over 4 passes that were at least 6%. my transmission was working great when they took it out.
my transmission is a off the shelf bd transmission with a heat treated input shaft. i have the standard lsx convertor in my truck, there is nothing hot-rod about my transmission other than the input shaft. they had my baseline pressure at 72psi.
this is what we found:
we cut the convertor apart and it looked great, there was hardley any wear on the clutch surfaces.
the forward drive clutches looked brand new, i could still read the part #'s. i'm sure the bands had wear, but i forgot to look at them. the 2 clutch packs showed wear. the clutch fibers were discolored.
what does this mean?
i can't beleive it held up as good as it did. i thought a shaft would have let go 100 launchs ago.
the reason i'm posting this is because no one can build a bullet proof transmission at my hp level. at least not one i could afford. i'm being honest about how my transmission looked. there was wear, and i'm no transmission expert but it held up great.
i'm putting down around 700hp through this thing and i couldn't be more impressed. i'm not saying this is the end all transmission but it's holding up to my abuse great. everytime i get in my truck i try and break this thing. we did raise my baseline pressure to 85psi this time, but that is the only thing different about this transmission. my job is to break this transmission so they can sell a product that the normal consumer won't have any problems with.
jim
jim
