My Block Heater Seams Weak?
3 weeks until my warranty runs out and BAM!
Cold Weather Starting Problem?
Just comparing it to another truck. The other one I could here it sizzle. Mine sounds quiet. Other truck fired up with ease. This one a little slower to get up to idle.
Tried an ohm meter with it warm. Measures at 18 if I did it right?
Also I can here water swishen around when I start it up from inside the truck. Goes away after a few secound. Any thoughts would sure be appriated. Thanks Jeff
95 Dodge Ram reg cab,2500,5spd,Tweaked & Peaked Cummins Diesel, MODS, K/N filter,dual exhaust 5'' tips,Lost muffler,turbo silencer, ACCESORIES,ISSPRO turbo & pyro. gauges. Shell Rotella in pan. Fleatgaurd filters. 130k. on the OD.
NO YOU CAN'T HAVE MY . 02 WORTH NOR HAS THIS MESSAGE BEEN EDITTED!
Jeff,of my two '95s the 2500 sometimes sizzles,the 3500 is quiet. When both have been plugged in the intake heaters don't come on,I feel this is the true test of how well the block heater is working. My theory on the swishing noise,which may be wrong,is that the boiling action around the heater element introduces air into the system. When you start up the noise you hear is the air passing thru the heater hoses. The air eventually escapes through the radiator overflow into the coolant reservoir.
95' 25004X4,AT,Driftwood,Banks Stinger,Warn fender flairs and running boards(Play truck)95 3500,5 speed,Driftwood,Banks&Phscotty,34,000 GCVW apple and tractor hauler(work truck)
This is not a reply, but a question. . What temp should the block heater be used? in the 30's?? It starts ok now. I know some of you guys are way -0. . I'm just curious. .
Or if I star having hard starts?
Also, how long do you leave it plugged in?
Thanks. ed
1997 3500 Dually CC, Emerald Green 5 speed, 4:10 , Reese 15K 5th hitch, K&N Air Filter, Jacob E-brake, gutted cat, running boards. Maybe more,if I can keep it out of DC'$ hands. .
What is the 'sizzle' sound that is coming from the block when I plug it in? I have left it plugged in for 5 minutes and it does not go away. I was concerned that there was something wrong and I would not leave it plugged it. Give me some idea's
Thanks
Rick
RICK
97 2500,CC,5 SPEED, 3. 54 Limited Slip,Psychotty System,K&N, ISSPRO 3" Pyrometer,Silencer Ring Removed
12,000 RBW 5th Wheel Hitch,25' Excel 5th Wheel,Rancho RSX17000 Shocks,Amsoil Dealer,Straight Piped
The "sizzle" is normal and is what I always listen for to ensure my heater is working. I usually use mine if parked outside below 20 degrees or so.
Ron
'96 Club Cab 2500 4x4, 4:10LS, Camper/Tow package, Auto, BD Pressure Loc, Mystery Switch, TST 230/605, Cat under "Test", Cummins Chrome, Mag-Hytec rear and trans covers, Boost, Pyro and trans gauges, Optima Red Tops, All black. Tow 14k HitchHiker triple glide 5th Wheel. Also use 9. 5' Lance camper. NRA Life Member.
That sizzle you hear is the heater perculating so to speak. It's a good noise, it lets you know it's working. #ad
You can plug in at any temp below 60f without any loss of sleep. The block heater would have to succesfully overheat the entire cooling system (block, radiator, and heater core) before any damage would occur. The cooling system on our trucks is way more than enough to accomadate this heat #ad
Jason Case
'95 2500 4x4 Auto Reg Cab
BD torque converter and valvebody, #5 fuel plate, BD 4" exhaust turbo back, K&N RE-0880,transmission temp, boost and egt gauges.
Pressure Lock installed
'99 KTM 300 EXC
What do you guys think about leaving the heater plugged in 24 hours occasionally? Of course, this would be done only if temps stayed below 40 degrees. I don't leave my home office every day, but when I need to go, I want the benefits of the warm engine.
I'm told that the wattage of this heater would only cost about a buck a day. (?)
'95 2500 SLT LB 2WD, auto 3. 54, 68,000--Westech gauges, Prime-loc, Brite box, Back-off Box, Line X, Flowmaster muffler, Borgeson steering shaft
Nothing wrong with having it plugged in 24-7. However it will increase the electric bill some, that is why some guys use timers.
