My body lift and pics
Brake controller plug and spade size?
A Better Block Heater Connector (?)
I got my 3" body lift, D25 front springs, 315-75-16 Bf's and 16x10 Atlas wheels mounted last night. It took a little extra work but I was determined to get the tires and wheels to fit. Thanks Rob for the help. The body lift does nothing but add to the appearence of these trucks. I love it. I can't believe the ride either, smooth as the small tires I took off. It really took a little of the bite off of those 4. 10's at highway speeds also. I love it. There are a few pics in my gallery. I will take some better pics when I get my good camera back from my daughter.
Cya, Dion
Thanks BBD. I followed Rob Thomas's install so he get's the credit for the ideas. On the hose going to the turbo all I did was twist the rubber hose at the intercooler around and it lined right up ( I think that it actually fits better now because before it had a terrible looking kink in it ). The intake hose had to be shortened. I cut about 3/4" off of both sides of the metal pipe. It has 2 flanges per side and when it's cut you push the rubber hose's up over the second flange and that gives you plenty of room. I really did not like the fan shroud part. You have to cut both of the bottom tabs off to get them to clear the intercooler. The body lift kit comes with 2 brakets to lower the shroud. I don't really like it so I have plans to put a big electric fan on in the future. That way I can raise my shroud back up to the factory position.
Cya, Dion
