Ian...
Now, for the ins and outs of so called "dual antennas". While it is a proven fact that properly installed Co-Phased antennas can exhibit quite a bit of signal gain over a single antenna, there are several things that have to be taken into consideration.
First and foremost, the antennas must be spaced exactly 1/4 wavelength apart in order to exhibit the elongated figure eight pattern you would be looking for. At CB frequencies, this would be approximately 8. 5 feet (102 inches). Anything over or less than that distance will distort the radiation pattern.
In order to feed these Co-Phased antennas, one cannot use standard 52 Ohm Co-Axial cable, as the total impedance of the two would only be approximately 25 ohms. Normally cable in the vicinity of 75 ohm is used to make the phasing harness.
I am not a believer of co-phased antennas for mobile work. I think the pain of installation, and tuning them, vs the actual signal gain for point to point low power mobile work are not worth the expenditure. Plus add to the fact the only true way to get the "dual antennas" into the 1/4 wave increment and make them work properly would be to mount on on the front of your truck and one to the rear makes them a hassle from the start. It is true alot of guys run them like this and close together,but,how many have ever looked at how the antennas tuned on a antenna anyalyzer. I realize its your truck but I figured after all your hard work installing the radio someone should tell you about the antennas so you do not have to tear the radio out because its been burned up due to poorly performing antennas... ... ..... Andy
