Yes, Found On Road Dead! Okay, I didn't actually find it, I was in it when it died, going 70mph on the highway. Shifted into neutral and after long crank it restarted, only to die out 5 seconds later. Pulled over, long crank, die after five seconds. Repeat a few times, then no start at all. Check engine light on.
I have a broken hand and a plow on front of the truck so I wasn't able to do much tinkering on the side of the road. Waited an hour and a half for a tow truck. Just before tow truck arraived I tried to restart and it fired up. Check engine light off. Tow truck followed me for two miles and truck died again. Long crank, restart, die. Repeat. Check engine light on. Towed the rest of the way in.
No early warning signs that I noticed. What is wrong with my truck? 3/4 tank fuel. New fuel filter. 28 degrees outside. 54,000 miles. Rarely run Edge Juice higher than level 2. I think all other info is in my sig. Thanks 4 the help!
