I would like to share with all of you what I went through and exactly what I did to convert my truck to R-134a. Just to give some background on myself and those around me my dad is a retired district manager for Chrysler my brother works for the local dodge dealership as tech and I have worked for the state for the last ten years doing commercial heat and air. Before I did the conversion not being very familar with auto a/c's because I don't deal with them much especially conversions. I had heard all the rumors about not cooling as good, smaller molecul,e gel oil, and higher pressures etc. Before I did the conversion I called Sanden compressor corp (who makes our compressors) to find out if our compressors would work. The guy I talked to said yes if fact our compressors would work and to not worry. He also stated to me that at the time R-134a was introduced that they believed a different type of o-ring was required (note I said required not reccomended) becaused they believed at that time the others would fail. He told me that over time that theory was proven untrue it is not neccesary to change the 0-rings. My next two phone calls were to Auto air of Oklahoma and to M. D. Heck corp here is oklahoma. Both of them told me that the hoses would work fine and they do not need to be changed. They also told me that the only reason to change the oil in the system was because the R-134a would not adhere to the mineral oil and would not travel thourgh the system to lube the compressor and the compressor would fail within a year if not changed out. My air quit because the pop-off of the back of the compressor blew due to high head pressure caused by a faulty fan clutch. Otherwise it would still have r-12 in it. When I did the conversion I had to pull the system apart to put a new expansion valve and blow off. I had to pull the compressor to drain the oil while I was there I went ahead and put new o-rings and yes they were green. I flushed the system with mineral spirts and blew out with an air gun. I put a new expansion valve which is the exact same one as R-12 and a new dryer. The dessicant in the dryers are different meaning the R-12 dryer will release the moisture it has trapped using R-134a. But I was told that a R-134a dryer will work for R-12. After all this I put the system back together and pulled a deep vacuum for about an hour. Checked for leaks and pulled again for another 30mins. So far I have only added 24oz of R-134a and I consistently get 50 degree air from the vent. The coldest I ever got from the R-12 was 55 and yes my expansion valve was probably bad. The book calls for 38oz of R-12 and everyone told me that you use 80% for R-134a so I think it will probably need more but I am just seeing how things are going to work first. Oh and just for FYI our compressor call for 135cc of PAG 100wt which I believe is around 4-5oz. Overall I am very happy with this conversion it beats going out and paying $20 for 12oz of R-12 and my initial impression is it is going to work just fine. I am not suggesting that everybody go convert but these are some things I found out while doing mine. My pressures at this point 85degrees outside 200psi high and 20psi low. I have not checked superheat or to see that the whole evaporator is saturated. I think that there is room for improvement and will post end result later. Again other experience's may be different from mine and if any info that I was told turns out to be untrue I will post. Now its time to go enjoy the cold.
