I have a 1998 Dodge diesel that had a noise in the torque converter area. It sounded like marbles in a can when in reverse and sitting still. I just pulled the transmission and flexplate to find out why. I expected a cracked flexplate, but instead, the flexplate has shaved off some aluminum off the engine adapter in the lower area under the engine crank. The flexplate has aluminum shavings on it thru the vent holes. Could a bad torque converter cause enough flex to do this. There's no cracks in the flexplate.
Any advice is nice as I need it put back together asap due to work needs. Thanks, Herb:{
