I drive 62 miles one way to work each day and started a little experiment to see what I could do to increase my fuel milage. I started off in my trucks "regular" configuration (see sig, also included bed mounted tool box with about 200 lbs of tools and junk) getting 19. 8mpg indicated on the over head computer.
I yanked the toolbox and moved up to 20. 6mpg.
I lowered the tailgate and got 20. 8mpg
I pumped the tire preassure to 50 and got 21. 4pmg
I removed the front replacement bumper (about 250lbs or more) and got 23. 5mpg
Then I changed the setting on my Edge Attitude from level 3 (drive) to level 1 (milage) and got 25. 4mpg.
These were all averages after a round trip 2 days in a row each, using the same roads, roughly the same weather and times of day. They arent perfect as I said I was using the over head console, reseting it after toping off the fuel tank before each trip.
I just grabed my fuel recipts to double check and got the same numbers for each trip give or take . 2 or so.
My next step will be to replace the cat with a test pipe. Also I'm due for a oil change.
Just thought I'd share with yall
