I have a FASS 150/150 system that I installed this summer, with the factory fuel filter housing eliminated and have about 4,000miles on it now. I also have a Vulcan Drawstraw installed in the factory module, with the one screen cut out and the bottom one left in the pickup of the factory fuel module. This summer I was seeing 20-21psi at all times. As the weather got colder this winter, I was seeing 15-16psi when I start it up in the morning (it sits outside, but I plug it in at night) and once I got up to operating temp. the press. usually came up to 17-18psi. This is ok, I expected this since I eliminated the factory fuel heater. We got some cold spells around here about a month ago (20-30*F at night) and when I'd start it up, press. would be about 14psi, and come up to 16psi once heated up. Now I'm seeing 12-13psi at start up, and I gotta drive atleast 30miles until I'm getting 15psi and thats about as high as it goes. Its doing this even in 45* weather.
Is it possible that my fuel filter is plugging up already? I use 1qt. of 2-stroke and half a quart of PowerServices winter fuel treatment at every fill up in the winter. Also, can the overflow valve on the injection pump fail in the open position? I replaced the pump and installed my fuel pressure gauge (with isolator) about 2,000miles ago. I replaced the overflow valve at the same time, so I'm kinda doubting thats bad already, but I can't imagine that my fuel filter would be plugged up already too. All my FASS system electrical connections seem to be ok, nothing loose or corroded. It sounds like the pump is running just as fast and not any harder than it always has.
