Here's my lift pump story.
I've been running on the same lift pump for 50 kmi. I never thought there were any problems. But recently, I developed a bad stumble. It became more pronounced after I installed my Super-Mental injectors. Now it couldn't be fuel, because I still had 11 psi at idle and 8 psi (no box) WOT. So I went searching. APPS? Too expensive. CPS? No, that checked out. IAT, MAP, APPS (eventaully) all checked out fine. Could it be the VP-44? I hoped not.
I was convinced that it wasn't the lift pump because I still had the right amount of pressure (mechanical gauge calibrated at work). But I thought that a pusher pump might be a good idea because I could starve the pump with the box on. So I ordered a Summit Pump (part # SUM-G3134) 15 psi 140 gph. Thinking this would be a superior pusher pump. I was gonna install a check valve in parallel with each pump so that if either one failed, the other would be able to continue to work automatically. Thought I was pretty smart.
The next day my pump started mis-behaving. Can you believe it? What carma. I videoed the gauge behavior so that those of you who don't know what to look for, can see what a failing lift pump does.
Video 1. This is during the startup. Pumps running, no pressure.
Movie 2. This is idling in the driveway.
Video 3. This is going down the highway at 65 mph.
As soon as I got to work, I called my dealer to let them know that my lift pump was going bad. Now I have an awesome dealer. They called me back a little later and said they had the new pump on hand and could install it whenever. I got it done. I told them I wanted to analyze the old pump once it cleared warranty. After a couple of days, they gave me my old pump.
I drove it home at 14 psi and 8 psi WOT. It was like driving a new truck. I had all that power back. But I had the pusher pump, so I might as well install it to help the new lift pump live longer, right?
I installed the pusher pump. I tapped into the new jumper piece that came with the new lift pump to power the pusher pump. I mounted the pusher to the frame rail just ahead of the t-case support. Started the truck and... HOLY COW!!! Over 30 psi
. Turned down the reg as far as I could. I knew this was bad. I finally got it down to 27 psi. Still too much. What do I do without spending a ton of cash? Regulator? Bypass original pump? Run original pump until it dies then put in pusher?
I finally decided to retire the stock lift pump in place. I took the old wiring harness of the original lift pump and mated it to the new pusher pump. I then re-worked the plumbing so that the pusher pump flows right into the filter. I took the line from the original lift pump, cut it on half, installed a piece of flexible hose inbetween the halves (so I could bend it) and used it to cover both ports on the old lift pump. I also took off the old electrical adapter piece and put it in the truck box. This way, if the pusher pump fails for some reason, I can put the "new" lift pump on line in short time so that I can still drive the truck. I hope I never find out.
I started the truck, readjusted the regulator to 16 psi and drove on down the road. No more stumble, and plenty of fuel to spare.
That's my solution to this problem (for now). What a way to fix a problem I didn't think I had to start with.
