..... well sorta !!! I just installed new Bilstien Shocks (Blue/Yellow) and Toyo Open Country MT's. What a difference. The shocks definitely smoothed the ride out a lot. The originals had about 102k miles on them. I put them on first and rode around to check the ride and was very pleased. One side effect I wasn't expecting was the rear sits a little higher than before. I'm somewhat surprised at that.
Then I had the tires installed and they just added to the ride quality. They replaced worn out 265 Bridgestone Duelers that had a far amount of sway in them. I went with 285/75/16, they're 10 Ply, E Rated @ 3740lbs max 80lbs pressure. I luv the look of the bigger tire filling the wheel well. They're on stock 2002 rims so they are a perfect fit and the stiffer sidewalls sure added to the tracking ability while eliminating the mushiness.
Now the question, with these tires rated up to 80 psi, what pressure should I run them at when running empty? I'm thinkin' maybe 60 front / 50 rear but not sure. These puppies where expensive and I wanna make 'em last so whadda you think?
TIA
TIA
