After some of the talk lately about torque tubes, usefullness, etc. , I decided to dissect my factory unit and see what I could do to it. I heard soooo many people say that they "cut" the guts out of the factory unit, I wanted to see what it was gonna take to do it.
I was certain that there was a way that the tube itself would come apart to be able to remove the insert instead of destroying it by trying to cut it out. Sure 'nuf, I saw the seam at one of the connection points. I took a small screwdriver and went around the seam to pry it apart. By prying it apart, you break a glued connection, but the lip on one end comes out and allows the guts inside to slide right out. What I did then was put a bead of high temp RTV around the sealing surface, drilled four holes and used sheet metal screws to insure that the connection lip didn't seperate from the main body. What you get is a factory lookin' tube with no guts and no cutting.
What you see in the pictures is the tube itself, the insert, and the white piece is what is in the bottom elbow that attaches to the turbo.
I wanted to try it to see what I thought of the new sound. The sound is AWESOME ! I love it. Others may not like it, but I wanna hear the turbo spool. The best part is - - it cost me ZERO, and I can always replace the insert if I choose to. I didn't destroy anything with what I did.
Whatcha think ?
Whatcha think ?
