Hey folks... My '90 D250 is starting to show its age. It has 190,000 miles, runs well, and I just put a $1000 front end rebuild in it and 4 new tires, but I just started developing some other problems.
For a while now, the engine will make an erratic "ticking" noise. I believe this may be a sign my injector pump is getting ready to go out on me? I think I may have read this in the past. While the engine is idling, it will do it most all of the time now. It used to be only now and then. The noise is kind of like tapping a nickel on top of a can... very erratic, yet consistent.
The noise that is really bothering me is coming from the rear. It started last weekend after I towed my friends boat out to a river and back, about a 70 mile trip. Everything went fine, but when I got back after unloading the trailer on the way home this noise started up. It would only do it from 25 mph + but now it does it at all speeds. It sounds like it varies with speed, but its not very pronounced... you can't hear it 'winding down' with your MPH it just sort of 'stops. ' It almost sounds like a balloon squeaking air out of the neck at low speeds before it stops around 5 mph. At higher speeds its a higher pitched howl. I fear the worse. I drove 700 miles on Sunday, the day after the fishing trip, up to Philly and back with no problems. Only noticed the noise for a little while on the way up there, it didn't do it the whole time. Either i can't hear it on the interstate, or its not making the noise. I probably just can't hear it. The differential fluid was changed, with proper additive, about 5000 miles ago.
Thanks for your time. .
Wes
Wes
