MY POWER STEERING HAS A LEAK - HELP
auto trans to 5spd
Braided Brake Lines
I THINK MY P/S PUMP IS LEAKING
THERE A SOME DRIPS UNDER IT AND LOTS
OF DRIPS ON GROUND ITS NOT THE VENT
TUBE
IS THIS COMMON? FIT EASY?
BILL
1993 w350 ex cab, banks,nv 4500 in
open exaust, pw Injectors are in. Big rig flaps,tach in,. Its loud and goes ok, for a 93,Ham radio Call KK6dm
has ability to communicate any where in the world. Headliner shelf
5 antenna's
Power steering pump on my 93 d-250 was damp and couldnt see the leak. Had to watch it for several minuets while running . Finally saw a drip from the fuel pump bracket onto the P/S pump.
Bob Fulgham
In the aluminum casting between the vac. pump & the p. s. pump,theres a o-ring & a oil seal. If either one of these goes bad it will leak motor oil. The fan will blow it all over making it hard to pinpoint the leak.
I've replaced a few of these seals before, not a real tough job. Just another place to check for leaks.
CPFF
CUMMINS POWERED FAST FORD
Hi drivers mopars,
I had to replace the power stearing pump on my 1992 back in 1998. At the same time I had the Borgerson stearing coupler installed.
Al
92-LE,4x4,5spd,3. 54,Borgeson steering shaft, Tach,Isspro Pyro & Boost, 16cm2, PW injectors
I've had a leak for about 6 months coming from between my ps pump and vacuum pump. Haven't had time to fix it but I will eventually. SURE MAKES A MESS!
1995 3500 Ext. Cab, 4x4, 5 speed manual, and South Bend's 300 HP Clutch; SuperLift SuperRide Shocks; removed silencer ring; 3" straight pipe w/Banks turndown tip; Adjustable Diesel Performance Propane Injection; Autometer UltraLite Boost; Custom 1400 watt stereo with 2-6"x9", 2-6. 5" Blapunkt mid/high ranges and 2-10" AudioBahn Subs; Dual RED top Optimas; Cobra CB and Police scanner; Motorola UHF Two-Way radio; Lund winterfront; 316,653 miles and still adding 50+ a day.
You know, I don't really believe in all that stop seal goo that all the additive companies sell but, and thats a big but, I added the Slick 50 Power steering additive for leaks from my steering box. Low and behold it worked, now a year later, dry as a bone. Can't explain other than it re-hydrated the O rings and things that seal. Weird stuff.
J-eh
Jason Hoffman
Lil' Mack - 89 D250LE 5 Spd 3. 54 LSD Reg Cab. K&N,"tweaked pump", BD Injectors, Banks Pyro/Boost, 3. 5" Exst tail section straight. E&M Custom seats. Bosch H4, PIAA 80W/80W HdLites. 100W Drv,55W Fogs.
237,500 miles (380,000 Kms) 7850 Hrs. Cummins Power Booster member.
The Original Turbo Diesel
Lil' Mack Pics/March 2001
Thanks guys, my P/S has been leaking for a while now. I hate to think about replacing the pump, so I think I'll try the Slick 50 fluid. I agree with Lil' Dog on the goo sealers. I'm getting rather annoyed by having to put more fluid in the resevoir every three to five days (yes, it leaks that fast :{ ) Right now, I'm willing to try anything that anybody suggests.
About 3 weeks ago I fixed a leak in my power steering system. I saw the dreaded drops on the ground and was expecting the worst.
Turned out it was a leaky hose. The pressure hose was leaking from the steel fitting. It would only leak when the steering wheel was turned, so I needed someone to turn the wheel so I could find it.
Less than $20 and an hour later and I was up and running again.
Sometimes we get lucky.
