I just installed a standard Quad box. Thought I had everything right, turned on the ignition but didn't start the engine. I didn't get any lights on the box that are supposed to light at start up. Shut the ignition off and went over the plugs again and found the fuel rail plug was in backwards. Made the correction and tried again and all lights lit normal. Went for a drive and then noticed the check engine light was on. Will this clear itself or could I still have a plug not right?
